Carburetor for a 22R-E
1986 TOYOTA PICKUP
155,000 MILES • 4 CYL • 4WD • MANUAL
SFCTRIPLETT57
  • 184 POSTS
I have the truck listed above that has a 1993 22R-E engine in it. I'm looking for a carburetor or carburetor kit for a 1993 22R-E Engine.
is a 22R-E Engine equal to a 2.4 L and will a carburetor from a 2.4 L work on a 22R-E Engine.
Thanks for your help.
Mar 31, 2021 at 2:25 AM
Good morning,
The 22RE is a fuel-injected motor and does not have a carburetor.
Did you use the block and change over everything from the 1993 to the 1986?
I attached the carburetor for the 86 below for you. Rock Auto offers the carb and the kit for rebuilding. I would get the entire carburetor.
Remove the linkage to the carb. Remove the electrical connectors. Remove the inlet fuel line. Remove the vacuum lines. I suggest you mark them and also take a picture of how they are routed. Then remove the 4 mounting nuts and carb comes up and out.
1. Loosen pivot retaining screw and remove fuel metering needle, Fig. 3.
2. Disconnect fast idle link from choke lever, remove air horn screws, then separate air horn and place assembly next to carburetor body.
3. Loosen and remove fuel cut solenoid by rotating carburetor body to complete air horn removal.
4. Remove float hinge pin, the float and needle valve assembly, then the needle valve seat.
5. Loosen power valve piston retainer screw, hold piston and rotate retainer, then remove power valve piston and spring.
6. Remove outer vent control valve from air horn.
7. Remove dashpot and bracket from carburetor body, if equipped.
8. Remove slow jet, power valve assembly, metering rod guide and secondary main jet, primary main jet plug and the primary main jet and seal. Record stamped markings and installation position of calibrated components as they are removed to ensure proper assembly.
9. Evenly loosen screws securing accelerator pump housing, then remove pump housing, diaphragm and spring.
10. Evenly loosen screws securing Auxiliary Accelerator Pump (AAP) housing, then remove housing, diaphragm and spring.
11. Remove hot idle compensator cover and gasket and the thermostatic valve and seal, if equipped.
12. Disconnect idle up diaphragm link from throttle lever, then remove diaphragm assembly.
13. Disconnect choke opener diaphragm link, if equipped, then remove diaphragm assembly.
14. Remove throttle body retaining screws, then separate throttle body from carburetor.
15. Remove idle mixture screw concealment plug, rotate mixture screw clockwise until lightly seated recording number of turns necessary, then remove idle mixture screw.
Mar 31, 2021 at 5:29 AM
SFCTRIPLETT57
  • 184 POSTS
Sir the person that owned the truck changed it over to a carburetor.
Mar 31, 2021 at 9:36 AM
I figured that since the engine was the 22RE. You can use the carburetor that I posted.
Mar 31, 2021 at 9:41 AM
SFCTRIPLETT57
  • 184 POSTS
Thank you Sir.
Apr 1, 2021 at 3:16 AM
You are welcome.
Always glad to help.
Apr 1, 2021 at 5:01 AM
SFCTRIPLETT57
  • 184 POSTS
know anything on flywheels?
Apr 1, 2021 at 2:50 PM
Hello again,
Since we covered the first question subject matter, you need to start a new question for the flywheel. I would be glad to help you with the question once you start a new thread.
Apr 1, 2021 at 5:02 PM
I got a response but nothing came through.
Did you have a question?
Sep 6, 2021 at 2:40 PM
SFCTRIPLETT57
  • 184 POSTS
No Sir, I'm good, sorry.
Sep 7, 2021 at 3:37 AM
No problem. We are here if you need us.
Sep 7, 2021 at 4:29 AM
Do you have a follow up question?
Nov 9, 2021 at 9:32 AM
SFCTRIPLETT57
  • 184 POSTS
No question at this time.
Nov 10, 2021 at 2:42 PM
Okay, we will be here for you.
Nov 10, 2021 at 2:58 PM
SFCTRIPLETT57
  • 184 POSTS
Thanks.
Nov 11, 2021 at 3:21 AM
You are welcome.
Nov 11, 2021 at 4:29 AM
Did you respond? I got a response and nothing came through.
Feb 1, 2022 at 3:12 PM
Same thing. Got a response with no content.
Feb 1, 2022 at 9:24 PM
No content in your response again, sorry.
Feb 22, 2022 at 7:46 AM
SFCTRIPLETT57
  • 184 POSTS
Sorry, forgot what I wanted to ask.
Feb 23, 2022 at 1:27 AM
LOL. Been there, done that.
We will be here for you.
Feb 23, 2022 at 1:59 AM
Sorry, nothing came through.
Feb 24, 2022 at 2:47 AM
Same thing, sorry.
Feb 24, 2022 at 2:31 PM
SFC LARRY A. TRIPLETT
  • 7 POSTS
Sorry, having problems with 2CarPros website.
Feb 25, 2022 at 5:27 AM
No worries, we are here.
Feb 25, 2022 at 6:42 AM
Got some messages for you again.
Why don't you start a new question away from this question and see if we can communicate better.
Mar 28, 2022 at 6:16 AM
