Carburetor choke
1978 JEEP CHEROKEE
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARK FRIZZELL
  • 142 POSTS
I rebuilt the motor, bought and installed and up graded two bbl 1981 style carburetor with electric choke which it did not have before. How do I wire up the choke safely?
Oct 30, 2018 at 10:27 AM
Good afternoon.
Some of them were wired with a voltage supplied by a wire from the fuse box to the choke. Make sure you pick a lug with power with the key on only.
Another way is to do this same procedure but use a ballast resistor in line. That would make the choke stay on a little longer. If it comes of too fast you will have hesitation until warmed up.
One last way is to take a tap off the starter wire on the alternator. That is a little lower voltage just as the ballast resistor.
Oct 30, 2018 at 11:04 AM
MARK FRIZZELL
  • 142 POSTS
Thanks Roy.
If I use the alternator wire would that be the black wire?
Oct 30, 2018 at 11:32 AM
Check and make sure it has voltage with the engine running.
It has been a while since I did one and the information system does not show it. Just make sure there is no voltage engine off and voltage with it running.
Oct 30, 2018 at 11:49 AM
MARK FRIZZELL
  • 142 POSTS
Perfect! Thanks Roy.
Oct 30, 2018 at 11:58 AM
You are welcome.
Always glad to help.
Oct 30, 2018 at 12:05 PM
