Yep, it will do this when you have a vacuum leak, I would check the vacuum lines at the base of the carb along with the gasket and also check the PCV valve. You should check the carb mounting bolts/nuts as well I have seen those come loose, this video will help you find the leak.
https://www.youtube.com/watch?v=LRKWV4Are5c
Let us know how it goes
Apr 19, 2026 at 8:33 AM
