Car will not start when cold, unless primed and will not idle when running?
1984 TOYOTA TERCEL
146,000 MILES • 1.4L • 4 CYL • 4WD • MANUAL
FRANK DAVIS
MEMBER
1 POST
FOLLOW
Oct 24, 2022 at 7:52 PM
CERTIFIED EXPERT
This can be a problem with the choke, fuel control solenoid or you have a vacuum leak. I would check for the leak first when the engine is cold only, please follow this guide and get back to me. Also, check all the fuses as well.
