Carbon monoxide
2009 KIA SPORTAGE
116,000 MILES • 2.7L • 6 CYL • 4WD • AUTOMATIC
JOSEPHSTRICHKO
When I turn on my heat, I get a bit of an odor, but definitely have carbon monoxide getting inside my SUV.
Took it to a shop to see if there was a vacuum leak, was told they could not find one.
At this point, not sure where it is coming from.
Any idea's?
Nov 20, 2018 at 5:27 PM
A vacuum leak isn't going to cause the issue. If you are getting fumes from the engine, it is most likely caused by an exhaust leak. Was the exhaust system inspected? Does the tail pipe exit the side or rear of the vehicle?
Is the vehicle running properly or is the check engine light on?
Here is a link that describes the components and issues with an exhaust system. Take a look through it to see if there is anything that is helpful.
https://www.2carpros.com/articles/how-exhaust-systems-work
Nov 20, 2018 at 8:32 PM
JOSEPHSTRICHKO
Hi and thanks for getting back to me.
The engine seems to be running fine, have not had any check engine light coming on.
The exhaust system has not been checked, I do not think so
But taking it in on this coming Friday.
The tailpipes are at the rear of the truck.
Nov 21, 2018 at 6:13 AM
Welcome back,
When checking, look for rust and black carbon marks anywhere on the system. Black carbon commonly indicates a leak. The vehicle is new enough that I doubt there are body rust issues. However, inspect the floor under the vehicle for holes and make sure there is nothing damaged or preventing all weather molding on the doors. Also, if you notice the smell more when the heater or AC is on, suspect a leak under the hood.
One last thing. Not all exhaust leaks are loud. Often times, if there is a leak at one of the exhaust manifolds, it sounds like a ticking that may be noticeable when cold and go away when hot.
Let me know if you have any questions, and Happy Thanksgiving.
Nov 21, 2018 at 1:21 PM
