Car will not stay running after hitting a deer incident
2000 PONTIAC GRAND PRIX
212,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DALTON BOEGER
I have the car listed above gtp supercharged. after I hit a deer the car will start run for a few seconds the shut off.
Jan 9, 2020 at 5:55 PM
Good evening,
How bad is the damage? Can you upload a picture for me?
https://www.2carpros.com/articles/stall-at-idle
Did you check the fuel pressure to see if the pump is working? Check the wiring to the pump to b sure there is nothing loose.
Did you check for spark? Check the connectors at the ignition module to be sure they are not loose.
Lastly, look under the steering column and check the connectors as in the diagram I sent you for the ignition switch.
Without them, the car will do this.
Jan 9, 2020 at 7:04 PM
