The PCM fuse I referenced is in the same panel as the HVAC fuse. See pic 2 above.
Okay, we need to determine if there is spark and fuel to the engine. One is likely missing. That will help us narrow down what needs to be checked.
Take a look through this link and let me know if it helps. Also, see if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we lost fuel. If it doesn't, then there is likely an ignition issue.
Nov 14, 2020 at 7:12 PM
