Helllo. I have a 2000 Dodge Stratus. The car wont start. It starts on ether and has no fuel pressure at the rail. Fuses are good and swapped the relay with no luck. Is there anyway to test the fuel pump to see if its working? I found the connector to the furl pump in the trunk, but there are 7 wires on the plug so im not sure which wires to check for power. i was also going to try and send power to the fuel pump manually to see if the car would start but im not sure which wires to power. Any idea how to check if its the fuel pump?
Thank you for the help!
Jon
Jon
Jul 24, 2015 at 12:27 PM
