Hi:
Is the check engine light staying on when the engine is running? I ask because there are many things that can cause this type of issue, Fuel pressure, engine vacuum leaks, fuel pressure regulator, ignition coils, stuck fuel injectors and so on can all cause it.
If the check engine light stays on, have the computer scanned to identify diagnostic trouble codes. Most parts stores will do it for free. Once that is done, let me know the codes so I can point you in the right directions.
Here is a quick video showing how to retrieve codes just in case you can get your hands on a scanner:
https://youtu.be/YV3TRZwer8k
Do this and let me know what codes are found. If the check engine light doesn't stay on, let me know that too.
Nov 13, 2019 at 7:42 PM
