car wont start after i chabge fuel filter
2000 NISSAN PULSAR
180,000 MILES • 1.8L • AUTOMATIC
KEVINCASTROUND
  • 5 POSTS
I have put everything back as it was with the new fuel filter. I tried turning the key in on position for 3-5 times and the car still doesn't work. I don't know what is wrong or do i have to do something else. Please help me on this.
Mar 26, 2015 at 5:54 PM
Check to make sure the filter isn't backwards. If it is on correct, disconnect the filter on the pump side and see if there is fuel pressure there.
Mar 26, 2015 at 7:01 PM
KEVINCASTROUND
  • 5 POSTS
i have done that and it still doesnt work. i filled the filter with fuel, still doesnt work.
my car is nissan pulsar 2000 and the fuel filter goes inside the pump which sits inside the fuel tank.
I can hear the pump running everytime i crank the car so hopefully the pump is working fine but the fuel doesnt seem to go. Or there is no pressure.
Mar 26, 2015 at 8:05 PM
Then either the filter is installed incorrectly or the pump, although running, isn't producing pressure. I suggest that you remove the pump and bench test it to see if it is working.
Mar 27, 2015 at 5:29 AM
KEVINCASTROUND
  • 5 POSTS
Hello, i got your reply. I tried your suggestiom and it work. Thank you so much
Mar 28, 2015 at 4:37 AM
Glad to help. What ended up being the problem?
Mar 28, 2015 at 8:31 PM
KEVINCASTROUND
  • 5 POSTS
It was just the rubber that was suppose to hold the filter to the pump. It was small so i did not see it straight away.
Mar 31, 2015 at 5:30 AM
