car won't start
2008 GMC ACADIA
83,000 MILES
SUAVE523
I have a 2008 GMC Acadia. It won't start, it will act as if it is about to start but then when u expect it to start running it won't budge. i have tried jumping the car I checked the oil and antifreeze. I don't know what else to do.
May 4, 2013 at 3:01 PM
Hey SUAVE523.
These cars had a big problem with the fuel pumps going out, when you turn the key to the on position without cranking the engine over do you hear the fuel pump come on in the tank for 5 seconds? it could be the crankshaft angle sensor as well
This guide will help you get the problem fixed.
Run some tests and get back to us so we can continue helping you.
Jan 28, 2017 at 12:36 PM
JDL
  • 16,098 POSTS
Engine cranking, did you visually check for spark at the spark plugs? Did you use a gage and check proper fuel pressure? Also, check to see if pressure holds for a bit with everything off.
Can you check for fuel injector pulse? Can you check applicable trouble codes ? To check codes yourself, at the least, you need an obd2 code reader.
I'm not sure I understood your post?
Jan 28, 2017 at 12:37 PM (Merged)
SHAWNSMITH0889
  • 9 POSTS
Will not start. Doesn't have enough compression
SHAWNSMITH0889
  • 9 POSTS
Here is the code that came up on my computer
how do you know the compression is low???
the code is for variable valve timing.
SHAWNSMITH0889
  • 9 POSTS
I used a compression tester. If was around 80
ok, if all the cylinders are 80 then there is a good chance you have a failed timing chain.
SHAWNSMITH0889
  • 9 POSTS
My timing chains were replaced back in 2014 so I wouldn't think they would go bad again already
MHPAUTOS
  • 31,937 POSTS
Do a wet comp test to see if the rings are actually the cause of the low compression.
JOJOMSALAS
Electrical problem V8 Two Wheel Drive Automatic 35,000 miles
The engine won't start and the key is stuck in the ignition switch. There is no power for anything.
Jun 17, 2017 at 5:53 PM (Merged)
Its sounds like the battery is down on charge. Here is a guide that will help you test it and then replace the battery if it tests bad.
and
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Please run this test and get back to us so we can continue helping you.
GMCACADIA
My car will not start. The instrument panel illuminates, but the car will not turn over. I replaced the battery for the first time about three months ago. I notice that there is a high pitched ringing coming from two wiring harnesses that lead into the radiator. I do not know if those have been drawing power from the battery overnight, but does that sound like a fixable problem? Thank you!
Jun 17, 2017 at 5:54 PM (Merged)
It sounds like you may have a bad battery, do this test to confirm.
RCARRIZALES15
2008 GMC Acadia - cranks but won’t start - mechanic replaced fuel pump relay because of error code being displayed - took back after 1 week - he did full check and found a corroded wire leading to fuel pump under driver seat - he said it would be about $600 + but bypassed corroded wire and did not charge me due to fuel pump being misdiagnosed
Jun 10, 2019 at 7:31 PM
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Jun 11, 2019 at 10:24 AM
