Car will not start after shutting off while driving
1992 JAGUAR XJ6
198,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
running normally on freeway , suddenly the engine slow down and stops in the traffic. Have car towed to my home. Filled up the gas tank and car won't start.
Mar 25, 2020 at 6:33 AM
Good morning.
Did you run out of fuel?
If you did, you most likely damaged the fuel pump. The gas is both a coolant and lubricant for the pump.
Can you hear the pump run with the key on?
Mar 25, 2020 at 7:00 AM
