So, it started off that the water pump needed changed then the radiator replaced both put car back together it wouldn't start so had alternator tested i needed a new one so replaced alternator and battery. I've also replaced the spark plugs and checked fuses there good. Car cranks but sounds weak also there's a knock noise toward the end of cranking car will not start.
Nov 24, 2022 at 7:45 AM
