We need to perform a couple of checks. First, is the battery good and fully charged? Are the battery terminals clean and tight?
Next, is there any difference if you try starting it in neutral?
If that is all good, check the fusible link (30 amp) in the fusible link block. See pic 1
If the fusible link is good and has power both in and out, check for power at the starter. Pic 2 shows the starter. The wire from the battery black/yellow will have 12v all the time. Confirm that. The other smaller wire which is white should receive 12v when the key is in the start position, so you will need a helper to check that.
Here are a few links you may find helpful when testing:
https://www.2carpros.com/articles/starter-not-working-repair
Pic 3 shows fusible link H.
Dec 14, 2020 at 7:58 PM
