Car will not start after replacing spark plugs and oil
2001 TOYOTA AVALON
10,200 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LIDO1970
  • 5 POSTS
Car was running fine. I changed spark plugs and oil. Car turned on next morning car turned on but shut off then did not turn on tested the three relays that run E.F.I. all good .don't have 12 volts at fuel pump connector? Don't know what to do next. will start with a shot of starter fluid for about three seconds.
Jan 31, 2019 at 5:34 PM
Good evening,
The power to the fuel pump will be there for two seconds with the key on. It will be full when cranking. Did you test it cranking?
Double check and be sure. If you have power and the pump is not working, then you have a bad pump. If you do not then we need to do some tests.
I attached a wire diagram for you to view. Verify power to the two terminals of the circuit open relay with the key on.
Jan 31, 2019 at 7:59 PM
LIDO1970
  • 5 POSTS
I have changed the fuel pump and fuel filter. Pulled the two relays in fuse box and the one on the driver's side panel all good. Still nothing.
Feb 2, 2019 at 1:27 PM
Again, did you test for power to the pump? This could be a wiring issue to the pump and test need to be done to determine the failure.
Feb 3, 2019 at 2:47 AM
