Girlfriends car, started out it would crank in morning and run fine, but when you shut it off, would not run again for several hours. Now it wont run at all. I have changed the plugs, plug wires, two coil packs, the ignition control module and the cam sensor all with new parts. have tried resetting the security system, still no go, scanner only showed codes for cam sensor and EVAP purge valve (which I also changed) looking for other ideas to chase down but am currently stumped for ideas. any suggestions? have a sneaky feeling it is something to do with security system, but not sure.
Jan 5, 2019 at 6:15 PM
