Car will only move in reverse
1991 PLYMOUTH ACCLAIM
100,000 MILES
DAWN REID
Car won't go forward it will go in reverse and has been driving fine until last night.
May 8, 2020 at 12:54 PM
If the vehicle was driving with no issue and all of a sudden lost forward gears, it is most likely a shift solenoid issue. Basically it is not engaging 1st gear but it can engage reverse.
I am not familiar with the Acclaim shifter but you should have a manual shift option. This means you have P,R,N,D,L 3,2,1? If when you put it in D and it doesn't move, try putting it in L or one of the numbers. If it engages in these position then most likely it is a solenoid issue.
Let me know if this works and we can go from there. Thanks
May 8, 2020 at 1:20 PM
