Transmission shifts into drive will shift into reverse and neutral and park?
2003 HONDA CIVIC
190,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
TBARBER22
Car will not go into drive. I changed transmission dual solenoid still no fix. Is it fixable or do I need a new transmission? When I turn the key the park light and drive light illuminates.
Dec 30, 2024 at 11:28 PM
You could have a shift solenoid, but can I ask if you have the CVT transmission? If so, I would check the fluid condition and if it is burnt the transmission is bad and you will need another unit. This is a common problem with the CVT transmissions, I would run the codes as well.
Here is a guide to help you:
Please let me know which codes are stored so I can help you fix it.
Jan 1, 2025 at 11:11 AM
TBARBER22
I ran the codes only thing came back was O2 sensor changed dual solenoid still no drive. thanks for the response. should I try 2 change the torque converter solenoid as well?
Jan 1, 2025 at 4:30 PM
Sounds good, these transmission have a history of burning up the main drive belt. That is why if the fluid smells burnt this can be an indication of that.
Jan 2, 2025 at 10:25 AM
