Did your vehicle overheat when it the radiator hose broke? A radiator hose being busted would not keep a vehicle from going or going in reverse. If a vehicle is overheated usually what happens is the aluminum head, which has a lower melting point than the iron block warps and this cylinder head warpage causes the head gasket[s] to fail. A good a quick way to tell if this has happened is to do a compression test on your vehicle's engine. Here is a link below describing how to do this:
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Oct 16, 2019 at 5:00 AM
