Car will not drive, possible transmission issue
2007 PONTIAC G6
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMBER FOSTER
So it all started when I stopped at a stop sign and went to drive and the car wouldn't move. It started no problem but would not drive in any gear or reverse and there was no abnormal noises. Had it towed home and started researching the issue. Low fluid was the first check. Fluid was coming out of the test hole. Drained all fluid out and only about 3.5 liters came out so clearly it was low. It was really dark like oil. After more research we ended up changing the filter and flushing the fluid then filling with new fluid. Once finished I was able to drive it out of the garage. Cycled the fluid through the gears. Took it for a drive for about fifteen blocks. After stopping it was very delayed in first gear but once in second it drove fine. Got it home and now it won't drive again. Does anyone know what the issue Is? I Don't want to put anymore money into fixing it if it is going to end up being a bad transmission. Someone told me it could possibly be the torque converter? Any help is greatly appreciated. thank you.
Jan 24, 2019 at 1:13 PM
KENW1
  • 213 POSTS
Thanks for visiting 2carpros.com
This does sound like a torque converter or fluid pump issue. You can perform a line pressure test to confirm this. If line pressure is low the transmission would need to be pulled to replace these items. I'd recommend a good salvage yard unit or reman transmission if so. I'll post the test info below. Most parts stores have the gauge in their loan a tool program.
Tools Required
^ J 21867 Pressure Gage
^ J-21867-65 Pressure Test Adapter (5.3L only)
Important:
^ Before performing a line pressure check, verify that the pressure control (PC) solenoid valve is receiving the correct electrical
signal from the PCM.
^ Some conditions may be intermittent, therefore this test should be performed at least 3 times.
Install a scan tool.
Caution: Keep the brakes applied at all times in order to prevent unexpected vehicle motion. Personal injury may result if the vehicle
moves unexpectedly.
1. Start the engine and set the parking brake.
2. Check for a stored Diagnostic Trouble Code (DTC).
3. Repair the vehicle, if necessary.
4. Check the fluid level. Refer to the Transmission Fluid Checking. See: Fluid - A/T/Testing and Inspection/4T65-E Automatic Transaxle
5. Check the manual linkage for proper adjustment.
6. Turn the engine Off.
7. Loosen Exhaust cross-over pipe to allow attachment of J-21867-65 adapter (5.3L only).
8. Remove the oil pressure test hole plug and install the J-21867-65 adapter (5.3L only) and the J 21867.
9. Put the gear selector in PARK range and set the parking brake.
10. Start the engine and allow the engine to warm up at idle.
Notice: The total test running time should not be longer than 2 minutes. Running the test longer than 2 minutes may damage the transaxle.
11. Access the PC solenoid valve control test on the scan tool.
12. Increase the PC solenoid actual current from 0 to 1 amps in 0.1 amp increments. Allow the pressure to stabilize for five seconds after each
pressure change. Read the corresponding line pressure on the J 21867.
13. Refer to the Line Pressure specification table. Compare the data to the table.
14. If pressure readings differ greatly from the table, refer to Incorrect Line Pressure. See: Symptom Related Diagnostic Procedures/4T65-E
Automatic Transaxle/Incorrect Line Pressure
15. Shut the engine OFF. Remove the J 21867 and J-21867-65 (5.3L only) if used.
16. Apply sealant GM P/N 12345382 (Canadian P/N 1095348) to the oil pressure test hole plug.
Notice: Refer to Fastener Notice.
17. Install the oil pressure test hole plug.
Tighten the plug to 12 N.m (106 lb in).
18. Re-tighten the exhaust cross-over pipe (5.3L only).
Jan 25, 2019 at 12:04 PM
