Okay. So if it does nothing when the key is turned, we need to know if the security light is on and then when you say good voltage everywhere, does that mean you have proper voltage at the starter when cranking the engine? If you have proper voltage on both the B+ wire and signal wire then the starter should spin. If it is not, then you have a starter issue. However, since it is a new starter, I assume you don't have proper voltage at the starter.
Measure your voltage at the starter and tell me what you have at each wire while cranking the engine. Thanks
https://www.2carpros.com/articles/starter-not-working-repair
Oct 14, 2019 at 5:10 PM
