Engine shut off while driving will not start?
2011 CHEVROLET CRUZE
140,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
PETE_1986
Car shut off while driving hasn’t started sense. ABS light stability control and power steering all on.
Sep 2, 2021 at 5:19 AM
SQM
  • 6,383 POSTS
Shutting of while driving is a symptom of a faulty crankshaft position sensor.
Over time with all the heat and vibration the crank sensor can loose its calibration. It can stall the engine while driving. Many times you will be unable to start it back up. The crank sensor is located on the lower back side of the engine (see diagram). Keep in mind this crank sensor does require relearning/programming after replacement.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Is your check engine light illuminated? Typically when a sensor fails the engine light comes on.
Thank you.
Sep 2, 2021 at 3:14 PM
