Car will not accelerate
1998 MAZDA 626
268,000 MILES • 4 CYL • 2WD • MANUAL
RYAN LIEBERMAN
Cars not accelerating like normal i replaced ERG valve and TPS sensor. The check engine light is not on since replacing ERG valve.
Apr 18, 2022 at 12:23 PM
Ryan,
Did this happen all at once? When you replaced the components, are you sure no vacuum lines or sensors were left disconnected?
Since there are no codes and it has a loss of power, the first thing I suspect is you may have a catalytic converter that is partially plugged. When you drive the vehicle, are there any odd sounds from the exhaust? Do you ever notice a rattling from the exhaust?
Take a look through this link and let me know your thoughts:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Apr 18, 2022 at 6:21 PM
