Car will not accelerate
1997 PLYMOUTH VOYAGER
88,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
SEAN ACTON
On my way home from work I pulled up to a stop light and waited to turn. As soon as I was able to go my van would not accelerate I thought maybe I switched gears, but it still was in drive. I tried to apply more pressure to the gas pedal but it would accelerate. Next I hear a fluttering sound coming from under the engine block. I turned off my van and pushed to the side of the road. I turn the car on no problem turning over, but again I could not accelerate and the fluttering noise had gotten worst then before. I had to get my van towed back to my house. I thought it could be an axle problem or transmission. I just wanted to know what others thought before I spend a whole a lot of money on a problem that I could fix. Is going to be to expensive to fix?
May 16, 2016 at 11:33 AM
HMAC300
  • 48,601 POSTS
see if check engine light is on then put in different gear ranges like first, second and third, other than drive. it cold be a transmission problem or axle broken.
May 16, 2016 at 12:06 PM
