If you come to a stop light the car will not idle correctly. It either revs up to 3000 rpms or the idle dips below 1000 rpms and will stall. The car immediately starts right back up. At times driving down the road you get a slight lack of response from the gas pedal with lunging from the car. We have replaced the following...air filters, map sensor. It was placed on a diagnostic computer with the following codes
P0300 random misfire detected
P0068 manifold absolute pressure / mass air flow - throttle position correlation for vehicles with idle air control valve
P0101 mass or volume air flow a circuit range/performance
P0420 catalyst system efficiency below threshold (bank 1)
I doubt know where to begin..I'm on a limited income and can not afford a large service bill..please provide some suggestions.
Feb 12, 2017 at 5:18 AM
