I have replaced several items to fix car vibration which was eventually fixed by replacing the gasket in the intake manifold which had a large leak. However, now the engine cranks but will start momentarily after priming with starting fluid. I checked the pressure between the hose that comes from the filter and the fuel pressure regulator. When I turn the key on, I get no reading, but when I crank it, I get a reading around 60. I replaced the following:
Fuel pressure valve
Fuel pump relay
MAF sensor
Both belts
Crankshaft position sensor
All fuel injectors
Throttle position sensor
Spark plugs
Spark plug cables
Distributor
All motor mounts
Downstream oxygen O2 sensor
Front oxygen O2 sensor
Idle control valve
Fuel filter
Some vacuum hoses
Fuel tank cap-tank is full
Throttle is clean
Air filter is clean
I am leaning to replace the fuel pump.
Fuel pressure valve
Fuel pump relay
MAF sensor
Both belts
All fuel injectors
Spark plugs
Spark plug cables
Distributor
All motor mounts
Idle control valve
Fuel filter
Some vacuum hoses
Throttle is clean
Air filter is clean
Jul 26, 2022 at 8:21 PM
