Car will not start
2003 CADILLAC CTS
195,000 MILES
MICHELLE SISILIANO
  • 5 POSTS
The engine light is on. I will put the key in the ignition, it turns but nothing happens. All lights work and power windows work. I have checked all fuses, checked the battery they are fine. I had the engine light read the other day, several things popped up. Cylinder misfire was one of them. The low voltage battery light has been on two times recently while the radio was not working. Last time I drove it, no low voltage and the radio worked just fine. Any ideas?
Jun 7, 2018 at 4:50 AM
When you turn the key and nothing happens do all the lights go out? Also, the engine will not crank over (starter) correct? Is the security light flashing?
This guide will help us get started:
Jun 8, 2018 at 1:51 PM
MICHELLE SISILIANO
  • 5 POSTS
The engine is not cranking over. The security light is not on. We already tried resetting that too. I have someone working on it, but there is not any hope at the moment. We have tried numerous things. We are thinking maybe something electrical. Lights work, windows roll down, radio works. Just nothing from the engine.
Jun 11, 2018 at 5:58 AM
It sounds like a battery issue. Can you do me a favor and load test the battery by leaving the headlight on for twenty minutes? Here is a guide:
Jun 11, 2018 at 11:23 AM
MICHELLE SISILIANO
  • 5 POSTS
I hooked the battery tester to it. It had a voltage of 12.8.
Jun 12, 2018 at 8:42 AM
MICHELLE SISILIANO
  • 5 POSTS
I have also put in a new battery and that did not help either. I am up in the air about this car. I do believe it has something electrical with the problem.
Jun 12, 2018 at 8:44 AM
This sounds like the main relay has failed. Here is a guide to help you test it when you find it from the diagrams below:
Jun 12, 2018 at 10:27 AM
MICHELLE SISILIANO
  • 5 POSTS
Thanks, it may be awhile before I get it looked at. But I will respond when I figure it out.
Jun 14, 2018 at 4:58 AM
Thank you, I want to know what happens. Have a good weekend. :)
Jun 14, 2018 at 10:05 AM
