car will not move in 4 wheel drive once cranked
2007 CHRYSLER ASPEN
117,051 MILES
MECHANIC FOR CHRIST
I need help fixing this vechile correctly, this vechile makes a small clicking sound only when in park running but will not move once placed in gear,and it only has wheel hi @ 4 wheel low and 4 wheel lock
Aug 28, 2013 at 4:55 PM
Are you saying that it will only move if the transfer case is in 4wd? Explain what happens when you are in 2wd and put it in drive. Are there noises? Does it try to move? Also, has the check engine light come on?
Aug 28, 2013 at 5:23 PM
After thought... Make sure the 4wd actuator is getting power when you shift to 2wd. It may be sticking in neutral.
Aug 28, 2013 at 5:24 PM
