Car will not idle, and it will be hard to keep running in cold weather?
1988 CHEVROLET CAVALIER
153,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 75 POSTS
I've had this problem for a while even before head gasket blew in cold and wet weather car will not idle or respond unless you have the accelerator half way to the floor it's some kind of fuel problem fuel filter has been changed regularly spark plugs and wires are maintained I've thought of buying me a new throttle body.
Dec 16, 2024 at 4:21 PM
This sounds like the TPS is bad which was common on these cars, I would run the codes as well.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Here is the TSP location so you can check it out. Check out the images (below). Let us know what you find.
Dec 17, 2024 at 11:55 AM
TJMOWBRAY
  • 75 POSTS
I just recently changed the TPS.
Dec 17, 2024 at 2:38 PM
Okay, did you run the codes?
Dec 18, 2024 at 9:40 AM
TJMOWBRAY
  • 75 POSTS
No I haven't had a chance yet.
Dec 18, 2024 at 7:05 PM
Okay, let me know what you find when you get a chance.
Dec 19, 2024 at 10:44 AM
TJMOWBRAY
  • 75 POSTS
I ran the codes. Nothing flashed 12 over and over. Car runs fine in summer time but when temperature drops below about 60 degrees car will not idle or respond when accelerator is pushed unless half way to the floor.
Dec 19, 2024 at 7:47 PM
This can be a weak fuel pump, have you changed the fuel filter? Also, I would swap out the coolant temperature sensor as well.
Dec 20, 2024 at 9:31 AM
TJMOWBRAY
  • 75 POSTS
Figured it out 38 year old fuel injector broke while I was taking it out.
Dec 26, 2024 at 6:50 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Dec 27, 2024 at 10:43 AM
TJMOWBRAY
  • 75 POSTS
Bought new fuel injector from rockauto car still doesn't idle right. I observed while running new fuel injector isn't spraying but more like pouring fuel into intake.
Apr 23, 2025 at 6:57 PM
Sorry, I thought you got it fixed. I would make sure the ECM grounds on the engine or good, also did the old injector do the same thing? You might have a defective injector.
Here is a guide to help test the injector pulse to see if it is a computer or injector problem:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Apr 24, 2025 at 8:41 AM
TJMOWBRAY
  • 75 POSTS
Fuel injector was broken so I replaced it from rock auto car idles rough has a miss at low RPMs runs good at higher RPMs observed while running fuel injector seems to be dumping fuel instead of spraying could this be weak fuel pump? How do I check fuel pressure?
Apr 29, 2025 at 12:06 PM (Merged)
TJMOWBRAY
  • 75 POSTS
Also throttle body is blacked up.
MECHTRIX
  • 382 POSTS
Yes clean the throttle body for sure. also, i'd check the fuel pressure, regulator, and pump if cleaning the throttle body first doesn't help.
Apr 29, 2025 at 12:07 PM (Merged)
TJMOWBRAY
  • 75 POSTS
Where is the fuel pressure regulator located on this car?
Here is a guide to help you check the fuel pressure. I have seen defective fuel injectors cause the is problem due to resistance issues.
Fuel Pressure .................... 62-90 kPa (9-13 PSI)
The fuel pressure regulator is in the injector throttle body. Check out the images (below). Please let us know what happens.
