Engine will crank but not start
2015 VOLKSWAGEN JETTA TDI
74,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
APONIX1
A week or so ago I technically ran the car empty, technically in that gauge still showed 5 miles to empty but due to parking on an incline I suppose it was enough the car could not pull any fuel. Added some diesel maybe a gallon at most and car started perfectly. I stopped to get more fuel and drove home (20-mile trip) without incident or signs anything was wrong. The next morning the car just turned over and over but no start. I checked all fuses first and even replaced the fuel filter that I already had on hand just in case. I've cycled my ignition many times to prime and still no dice. More or less ignorant when it comes to cars, but I can work through most repairs but major engine repairs and the fuel system I've never had to address.
Feb 16, 2022 at 7:44 AM
BORIS K
  • 836 POSTS
It sounds like you might have a problem with the in-tank pre delivery fuel pump. Running the fuel tank empty most likely damaged the fuel pump.
A quick check is to cycle the ignition and listen for the in-tank fuel pump to energize. A normal pump will emit a light buzzing noise. A damaged pump will either hum load or will not switch on at all.
How to replace an in-tank pump:
How to replace a in tank VW fuel pump:
https://youtu.be/nq0kxzHtBT8
See below picture how the pump looks like.
Please let us know how you get along.
Cheers, Boris
Feb 16, 2022 at 9:13 AM
