Car will crank but not start
1999 OLDSMOBILE INTRIGUE
200,000 MILES • 2.1L • V6 • 2WD • AUTOMATIC
JJORDAN0711
  • 7 POSTS
My car will turn over like normal but will not start. Just replaced battery. Old battery seemed to be drained after a cold snap we just had here. Car cranked, started and ran fine the day before the cold weather. Cooling system has antifreeze in it. Engine just spins but will not start. any advice?
Jan 31, 2018 at 9:57 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Can you hear the fuel pump run for about two seconds once you first turn the key to run, before you turn the key to start?
If not is there any security or theft light remaining on past bulb check, about fifteen seconds or so or is the security light flashing?
Jan 31, 2018 at 11:06 AM
JJORDAN0711
  • 7 POSTS
Security light stays on with the key in the on position.. goes off when key is removed.
Jan 31, 2018 at 11:24 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Does the security light go out with the key in the ignition after fofteen seconds or so?
Jan 31, 2018 at 11:29 AM
JJORDAN0711
  • 7 POSTS
I can hear the fuel pump running. security light comes on with key in the on position. goes out when key is removed.
Jan 31, 2018 at 11:34 AM
JJORDAN0711
  • 7 POSTS
The security light only comes on when they key is turned to on. does not come on with just the key in off position.
Jan 31, 2018 at 11:36 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Does the security light ever go out with the key on the run position?
Is there any check engine light remaining on also?
Jan 31, 2018 at 11:39 AM
JJORDAN0711
  • 7 POSTS
When I am trying to crank the car all dash lights go off.
Jan 31, 2018 at 11:41 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, you have a few choices, if you have a scan tool or code reader see if you have any codes stored, especially any referring to the crankshaft position sensor cause it could prevent it from starting if it was bad.
Or you could see if the engine will start and run for a few seconds after spraying a few small shots of starting fluid into the throttle body to rule out any fuel system problem. so if it does start and run for a few seconds, then you know it has spark. which brings me to the last, checking for a spark on at least one cylinder while cranking over the engine, plus if you have a tachometer on the instrument cluster if it does not even show a cranking rpm of around 100 rpm. then you can almost bet you have a faulty crankshaft position sensor and/or wiring to/from it.
Jan 31, 2018 at 11:49 AM
JJORDAN0711
  • 7 POSTS
Tachometer needle does not move as you can see from short video.
Jan 31, 2018 at 12:05 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You may want to start to suspect a faulty crankshaft position sensor, but you should still try to retrieve any codes. Do you have or can you borrow a scan tool or code reader?
If you want to just try replacing the crankshaft position sensor, I could get you some instructions but I only see either a 3.5 or 3.8 engine, not a 2.1. If the eighth digit of the VIN number is an H, it is the 3.5 and if it is a K, it is the 3.8.
Jan 31, 2018 at 12:14 PM
JJORDAN0711
  • 7 POSTS
Yes I have someone coming over tomorrow who has one. I will post what I find out. Thank you
Jan 31, 2018 at 12:16 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, and post back the eighth digit of the VIN number.
Jan 31, 2018 at 12:18 PM
