Okay, you need to have the fuel pressure tested and see if there is any spark.
You can rent a tester at a parts store for the testing.
FUEL PRESSURE:
Ignition "ON" Engine "OFF" .................... 40.5 to 47.0 psi
With Regulator Vacuum Applied [1] ..... 3.0 to 10.0 psi Less than Ignition "ON" Engine "OFF"
REMARKS:
[1] May be checked with either of the following methods.
With Pressure Regulator Vacuum Line Attached at normal idle speed.
Ignition "ON" Engine "OFF" with 10 Inches Of Vacuum Applied To The Pressure Regulator.
Dec 17, 2020 at 7:06 PM
