car want start again after it warms up when turn off it want start til cools down
1993 HONDA DEL SOL
1.5L • 4 CYL • FWD • MANUAL
RICK38
  • 4 POSTS
I have a Honda del sol 93 1.5 liter man tranny when I drive to store or where ever and turn car off it don't want to start just turns over found its not getting fire again til it cools off could this be the ignitor not ignition ignitor because when it cools back down it starts just fine you told another thing then you said my car didn't have the senser you was talking about heard that igniter does this same thing but don't want to buy it if it something else is there a way to test just the igniter it has a new ignition coil on the car I put on back in summer
Feb 23, 2015 at 9:02 AM
KHLOW2008
  • 41,814 POSTS
Apart from no sparks if you are not getting fuel pressure, the problem could be due to a faulty main relay.
Feb 23, 2015 at 9:41 AM
RICK38
  • 4 POSTS
i have replaced the main relay its not fuel already its fire issue something to do with what ever would get hot and make it not start or have fire then cools off has fire and starts every time til gets warm again would the igniter cause this problem if igniter gets hot would it make car not start or is it something else that would cause this issue tried new ignition module too its not that either
Feb 23, 2015 at 1:56 PM
SCHUELERAUTOSERVICE
  • 8 POSTS
for the price put a reman distributor in it and im sure you wil be good
Feb 23, 2015 at 7:36 PM
KHLOW2008
  • 41,814 POSTS
It most probably is caused by the ignition coil rather than the igniter. New coils could be fail too.
Feb 23, 2015 at 10:56 PM
