Spark plugs are covered with soot. Did the following but no success:
Replaced the spark plugs.
Replaced the coils.
Replaced the fuel pump.
Two coils, one sitting on spark plug 2 sparks 2 and 3 and the other one sitting on spark plug 4 sparks 1 and 4. The new spark plugs keep on getting covered with soot. The vibration is steady.(even and continuous)
There is spark in all 4. One of the pin in both coil connectors has 12v current.
The in tank fuel filter is not replaced. The compression in all 4 cylinders is around 180 PSI.
Can it be the fuel filter or the fuel regulator giving the problem? Please answer
Replaced the coils.
Feb 7, 2021 at 4:25 PM
