Car turns over but won't start
2001 OLDSMOBILE ALERO
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AUBRIISMETAL
The starter will turn over just fine. I've tried a few things and am now stumped. When I spray starting fluid in the air cleaner it will burn that like the engine is starting until it all burns up then it will die so I think it's a fuel problem. I hear the fuel pump working when I turn the key. I replaced the fuel filter but I don't think that was the problem (I could blow air thru the old filter without much resistance). Please help, Thanks.
Sep 30, 2014 at 9:11 AM
DOCFIXIT
  • 18,828 POSTS
Need to check fuel pressure with gauge to be sure. If pressure checks good ten maybe a problem with injectors. Is check engine light on?
Sep 30, 2014 at 9:30 AM
