car turns over but wont start
1999 JAGUAR XK8
70,000 MILES
JPAPINEAU
car was running fine, my son started it up and moved it 20 ft. He left the key in the ignition. I thought it may be flooded and put pedal to floor and turned it over for about 10 sec. to no avail. after multiple regular attempts to start it. In the ownwers manual it references a security handbook that I didn`t get with the car. I was thinking here that it may of went into a theft mode or something. We have moved it around for short distances many time before without a prob. New plugs and two of eight ignition coils replace last year. Help
May 21, 2013 at 11:39 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
This may have something to do with the key fob. Will the key fob open the trunk or unlock the doors?
Also there are a couple things you can check.
There are a lot of throttle body problems
Here is what Jaguar posted...
1. Ensure that the ignition is OFF.
2. Remove intake duct from top of throttle body.
3. Using a suitable cleaning agent spray the throttle bore and throttle
blade. Do not remove throttle body to carry out this operation.
4. Allow to soak for 10 minutes.
5. Spray again and wipe away carbon deposits using a soft clean cloth.
Note:
There is a gray colored molybdenum coating on the throttle bore adjacent to the
throttle blade. Use care not to remove this coating.
6. Open the throttle manually using the external linkage and inspect to ensure it is
clean.
7. Operate the throttle using the external linkage to ensure that it operates smoothly.
8. Re install the intake duct. with this car.
Try this and then we can go from there
Jul 8, 2013 at 6:58 PM
