car trouble.could it be fuel filter?
2006 GMC ENVOY
144,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
DHEBERT
"MY 2006 GMC ENVOY,WHILE TRAVELING 50MPH IT ALL OF A SUDDEN FELT LIKE AN ELEPHANT JUMPED ON THE ENGINE AS SPEED WENT DOWN TO 25 OR 30 MPH.HOWEVER, IT HAS NOT HAPPENED SINCE AND THAT WAS 3 DAYS AGO.COULD IT BE A CLOGGED FUEL FILTER OR WORSE?????"
Oct 26, 2014 at 3:49 PM
CARADIODOC
  • 34,306 POSTS
Fuel filters don't get plugged instantly. They take a long time to get clogged up. There's a lot of things that can cause a car to slow down. There could be an engine running problem, a transmission problem, or dragging brakes. Based on your description, my guess is the transmission went into default mode. You didn't say what happened after that, but typically you just need to turn the ignition switch off, then restart the engine to get it back to normal operation.
Oct 26, 2014 at 8:43 PM
