Misfires when transmission is in first and second gear, also loses power going up a hill
2003 KIA RIO
74,000 MILES • 1.3L • V8 • MANUAL
TWM
My car starts first time but when put in first gear it misfire and same in second gear . When change to third fourth not too, bad but when climbing up hill I lose power. press acceleration but nothing struggling to climb. I have change the coil pack and fuel filter and the other filter but still the same . Been on the computer and sensor computer nothing came up. All the wires look fine. We don’t know where to turn next. Can you help me? Thank you
May 9, 2019 at 9:36 AM
Welcome to 2CarPros.
A few different things can cause this. Components such as a plugged catalytic converter, bad crankshaft position sensor, low fuel pressure, and so on can all have an affect on performance.
Here is what I suggest: Lets start with the basics. Make sure fuel pressure is within the manufacturer's specs.
Here are the manufacturer's specs for pressure:
Fuel Line Pressure .................... 46-51 psi (320-350 kPa)
___________________________________________-
Also, a bad crankshaft position sensor can cause a misfire.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Picture 1 shows the location of the sensor.
_____________________________________________
A partially plugged catalytic converter can cause this, too.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/catalytic-converter-replacement
___________________
If you have access to a live data scanner, I would like you to check the following:
Fuel Trims both LTFT and STFT
Next, check engine coolant temp sensors reading (ECT). The ECT tells the computer how rich or lean to make the air / fuel mixture. If it is indicating the wrong temp, mixture will be off and cause power and misfire issues. Also, the computer won't know that the sensor is wrong, so no code will be set.
__________________
Let me know if any of this helps, and what you find.
May 9, 2019 at 7:50 PM
TWM
Thank you for your response. My mechanic is fed up. now as I said before he has change coil pack plugs, air filter, fuel filler, been on sensor machine nothing came up. been on main computer nothing came up. He checked fuel pressure it’s fine he thinks fuel pump is okay, change sensors just in case . And my car still misfire and loses power. please, please any suggestions? thank you .
May 13, 2019 at 12:00 PM
Welcome back:
The only things I can suggest is for him to use a live data scanner to see what is actually happening when the misfire occurs. He may even want to remove an oxygen sensor to see if there is an restriction in the exhaust.
IF he has checked everything, something is causing an intermittent misfire. IT must be brief enough for the computer to not recognize it as a problem.
I wish I could provide a specific issue, but he has checked everything the same as I would have, but I don't know if he drove it with the scanner attached to see what was happening or if he considered a possible restriction in the exhaust (catalytic converter).
May 13, 2019 at 5:17 PM
