Car switching off and wont idle
2009 HYUNDAI I20
100,000 MILES
SHAKEEL
Car burning rich with fuel and causing spark plugs to turn black. Also, the car wont hold an idle and continuously switches off when slowing down, but when in motion runs normal. what could be the cause of this?
Oct 21, 2016 at 1:34 PM
JIS001
  • 3,412 POSTS
Check your mass air flow sensor. With a scanner that can read live data, look at mass air flow sensor reading. Should read grams per second. So if your engine is a 2.0L you should see something close to 2g/s on your reading. Tap sensor and see if readings change too much or drop out close to 0. If it does replace the Mass Air Flow sensor.
Oct 21, 2016 at 2:43 PM
JIS001
  • 3,412 POSTS
Forgot to mention, that reading is while vehicle idles and no loads on.
Oct 21, 2016 at 2:44 PM
AL514
  • 5,464 POSTS
Just to add, is the check engine light on?
Oct 21, 2016 at 4:50 PM
SHAKEEL
No engine light on. the car has normal readings just not holding idle and keeps switching off when slowing down. mechanic is saying head gasket then others says manifold intake gasket others saying o2 sensor, but what you are saying makes sense as it does sound like it is sucking in air and revs are under 1000 rpm's so it struggles to keep idling.
Oct 22, 2016 at 3:52 AM
SHAKEEL
Just to add, when mechanic plugged in machine he got an error p0108 map sensor.
Oct 22, 2016 at 3:55 AM
JIS001
  • 3,412 POSTS
Check your map sensor signal voltage. At sea level you should see around 1 volt.
Oct 22, 2016 at 9:31 AM
