I am sure that 7,000 RPMs was a typo? Should it not read 700 RPMs?
If the engine stutters at low RPMs with high load you most likely have an issue with the high-tension ignition system, either ignition coils or spark plugs. See image 1 below
The engine is fitted with eight ignition coils, 1 for each cylinder
How to diagnose a vehicle misfire:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
It would be good to have the engine control module checked with a diagnostic tool.
To check if there is a misfire counter on any of the eight cylinders and possible fault codes set. An easy way to test is to apply hand brake and foot brake, engage D and mash the accelerator down. Keep it there with brakes applied for a few seconds (max 5 seconds) and feel if the engine is stuttering, also with the scan tool connected and set to record misfire counters. This cam guides you as to which cylinder is affected.
How to carry out a CAN scan:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Hope this helps.
Sep 15, 2022 at 5:43 AM
