my car, during reverse it stumbles, and when taking off from a stop it's jerky. so to compensate for the problem to not happen, I have to hit pedal hard, the car never shut off on me, no check engine light, new ACdelco fuel pump, new spark plugs, and coil pack, new exhaust manifold gasket, new valve cover gasket. by the way this car model does not have a fuel filter, it's built in the pump. new throttle body, why because TPS sensor is connected to it, 2 new fuel injectors, I have a obd to look at my injectors it looks right, new down stream o2 however I think this may be the problem .I'm not that advance to no how to read trims to spot something. forgot to mention static fuel rail pressure was checked and it's holding no more then 3 psi loss in a minute. the picture of both o2 sensor while driving 45 mph. Also I have the ability to do a video of the reading live.
Feb 29, 2020 at 4:35 PM
