Hi again. If the lights are working, then either the shift interlock actuator or the cable which is the problem. I have attached several pictures for you to review. I do not know if you have a column shift or floor shift, so I attached both. The first pictures are for a shift lock override. It will allow you to shift out of park so you can use the car until it is fixed. The other pictures are of the aforementioned components. They are exploded views. Note, on the floor shift, the actuator is at the bottom of the shift lever. Also, picture 4 is part of the wiring schematic which shows the interlock and its position.
Let me know if this helps.
Jul 8, 2018 at 8:47 PM
