I have the car listed above it is the ES model (easy miles on it). My problem which I simply cannot find an answer for is why the car continues to stall at idle when warm or cold. I had an engine light on and pulled a code for a bad oxygen sensor which I replaced. After I replaced it the vehicle started quicker and ran better but then started stalling again. I do not have an engine light on so I cannot pull any codes now. I am running out of ideas on what else could be causing the stalling. The car starts right back up when it stalls but you can tell the idle is just not high enough right now to keep the car running when at idle. What else may be the problem?
Apr 27, 2018 at 10:09 AM
