Car starts will not drive after having the brakes lock up?
2012 NISSAN ALTIMA
120,000 MILES • 2.5L • 4WD • AUTOMATIC
JEN1478
The car had brakes locked up. Replaced all brakes pads car starts now but won't drive. It goes into gear. Brake pedal functions normally.
Jul 12, 2023 at 2:50 PM
It sounds like you have a bad master cylinder or booster. I would loosen the brake master mounting bolts three turns to see if the brakes release. If so, I would install a new brake master. Here is a guide and instructions on how to change the master out in case you need it. This guide may help as well:
https://www.2carpros.com/articles/a-comprehensive-guide-to-fixing-automotive-brakes-locking-up
You will need to bleed the master before installation.
https://youtu.be/WDxvEQrMkBg
Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Jul 13, 2023 at 12:20 PM
