You have a transmission problem, first i need to know if when you do put it in gear and rev the engine, is there any signs of it loading up or trying to drive? if not you need to get the line pressures tested as you may have a failed transmission oil pump, also just ensure that the transmission is actually selecting gears, with engine off, select each gear and make sure that the selector is moving on the transmission, start here.
Oct 31, 2017 at 7:51 PM
