car starts and idles but cuts out and dies when I put it in gear and try to drive.
1990 CHEVROLET LUMINA
140,000 MILES
JUSTIN2
I have had it scanned on a computer, the only code came up was an o2 sensor. I have changed the crank shaft position sensor, the throttle position sensor, the idle air control valve or sensor, & the map sensor. This was all on a mechanichs advice the same one that I payed to come scan it. Now he says it could be the electronic control module. If that is so where is it located? Are there any other things it could be? The mechanic said an o2 sensor wouldn't cause this but I don't know. Please help!!!!!!
May 29, 2013 at 12:10 PM
DOCFIXIT
  • 18,828 POSTS
What was code in POXXXx format Is the check engine light on? if so I need the codes first. If the engine light is off what were the codes before you replaced everything?
May 29, 2013 at 12:27 PM
JUSTIN2
What is a POXXXx format & I can call the mechanic I payed to scan it to find out.
May 29, 2013 at 12:42 PM
DOCFIXIT
  • 18,828 POSTS
Did you get code?
Jun 4, 2013 at 8:40 AM
