Car starting on its own?
2014 SUZUKI SWIFT
80,000 MILES • 1.0L • 4 CYL • 2WD • MANUAL
SILVERED
I went outside today, after being home for 4 hours and discovered my car was running.
I have a security doorbell and when I checked it the car turned itself on, with the key fob nowhere near it.
What do I need fixed?
Thanks folks!! :(
Aug 29, 2023 at 1:11 PM
STEVE W.
  • 15,113 POSTS
If you mean you hit the doorbell and the engine starts, it sounds like they are using the same frequencies. Nothing to really fix if that is the case as there isn't really anything you can do unless the doorbell or remote start can have different frequencies selected. The first thing I would do is to verify that hitting the doorbell starts it every time. If not, then it's possible something else is doing the same thing. So first will be to look and see if the remote start is a factory unit. If not, you might be able to change it out for one that doesn't have that problem. If it's a factory unit then see if the doorbell can have its frequency changed.
Aug 29, 2023 at 6:33 PM
