Welcome to 2CarPros.
The first thing I think of when you say it stalls with the AC on is the idle air control valve (IAC). The iac is designed to maintain engine idle speed. There is a idle air volume relearn I want you to try. Normally it is done with a computer, but I was able to find a procedure to do it without. Try this.
________________________________
Without CONSULT-II
1. Turn ignition switch "ON" and wait at least 1 second.
2. Turn ignition switch "OFF" and wait at least 10 seconds.
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic "PRE-CONDITIONING" , are in good order.
5. Turn ignition switch "OFF" and wait at least 10 seconds.
6. Start the engine and let it idle for at least 30 seconds.
7. Disconnect throttle position sensor harness connector (brown), then reconnect it within 5 seconds.
8. Wait 20 seconds.
9. Make sure that idle speed is within specifications. If not, the result will be incomplete. In this case, find the cause of the problem by referring to the NOTE below.
10. Rev up the engine two or three times. Make sure that idle speed and ignition timing are within specifications.
NOTE: If idle air volume learning cannot be performed successfully, proceed as follows:
1. Check that throttle valve is fully closed.
2. Check PCV valve operation.
3. Check that downstream of throttle valve is free from air leakage.
4. Adjust closed throttle position switch and reset memory. (Refer to "Basic Inspection".)
5. When the above four items check out OK, engine component parts and their installation condition are questionable. Check and eliminate the cause of the problem.
It is useful to perform "TROUBLE DIAGNOSIS - SPECIFICATION VALUE". See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes > Specification (SP) Value
6. If any of the following conditions occur after the engine has started, eliminate the cause of the problem and perform "Idle air volume learning" all over again:
- Engine stalls.
- Erroneous idle.
- Blown fuses related to the IACV-AAC valve system.
Removal and Installation
IACV-AAC VALVE
Please refer to Engine/Diagrams: See: Engine > Exploded Views > Outer Component Parts
If you need guidance with one of the things listed, let me know.
Jul 20, 2019 at 10:00 PM
