Car stalls on idle, quits randomly at red lights
2004 HYUNDAI TIBURON
100,000 MILES • 2.7L • 6 CYL • AUTOMATIC
BUGSAUTO
Stalls on idle, quits running randomly when stopping at red lights, sometimes will "sputter" while driving. Will usually start up fine on cold start but once the engine warms up, then the problem starts. The engine will sometimes die, then once it cools off a bit, will start right back up. When it quits, it's like something just shuts off the fuel and it kills the engine. It is getting fire, have checked plugs, wires, have replaced fuel pump, I have checked the catalytic converter, it isn't clogged. Also, it shows no codes
Sep 24, 2015 at 7:35 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner if it continues then check fuel pressure with a gauge, auto parts rent it.However this may need an adapter if it does a local pro will have to check pressure.
Sep 24, 2015 at 8:35 AM
BUGSAUTO
I appreciate the input. It acutally turned out to be the temperature sensor.
Oct 14, 2015 at 6:09 PM
