Engine shuts off and will not restart until it has sat for about an hour?
1997 HONDA PASSPORT
200,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
BLESSMYSTRESS
The car turns off out of nowhere, then it will only start back up after it has sat for about an hour. Then it starts and the same problem repeats. I need help!
Aug 30, 2022 at 10:41 AM
When it stalls can you hear the fuel pump running in the tank? If so, then I would run the codes and if none comes up replace the crankshaft angle sensor.
Here is a guide and the location of the sensor in the images below:
and
https://www.2carpros.com/articles/engine-stalls
Aug 30, 2022 at 6:16 PM
